Lt1 Pm Rods Or Gm Pink Rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2003, 11:49 PM
Someone made the comment that the new 350 LT-1 rods were lighter and stronger than the GM PINK rods. Is this true? If not what would be a safe max rpm range and horsepower amount for a GM steel crank, LT-1 PM rods, and hypertauntic pistons?
Old 09-23-2003, 04:55 AM
302 Z28's Avatar
It's true, the PM rods are lighter and stronger. GM lists the max rpm for the Fastburn crate engine at 5800rpm. I am quite certain it is considerably higher than that.
Vince
Old 09-23-2003, 05:29 AM
BOBCRMAN@aol.com's Avatar
Local shops are building IMSA car engines with the PM rods and they are more durable than the old pink rod, just replace the stock bolts, these rods are seeing more than 7500 rpm constantly.
Old 09-23-2003, 08:53 AM
V8 S-10's Avatar
v8s10.org
Thats what I put in my 383.
The only bad thing that i've heard about them is that rather than bending..they break
Old 09-23-2003, 09:05 AM
Sandflea427SS's Avatar
Anything with a throttle
I've gotten a few sets off of Ebay for $40-$50. I think they're great. I agree on replacing the stock fasteners. It's no question to go to ARPs. The only bad thing is that GM released a tech notice stating not to heat the little end when installing pistons. Even though I got a set that were already a little blue....I know it was an original set in a motor and it looks like GM heated them!
I'm building some el-cheapo parted 350-383s for testing purposes and will let you know how they last!
I expect to safely get 500-550 horse until they expire...I'll add more nitrous til they do.
2 bolt block....9000 series scat crank.....PM rods...Hyper pistons...pro topline heads.....
Old 05-02-2012, 10:25 AM
Richiehd's Avatar
JS-70
From another source....interesting read
http://www.superchevy.com/technical/...rds/index.html
Old 05-02-2012, 11:54 AM
I beat to a different drummer, I don't use PM at all and I dont like fracture cap technology.
For a hot street or claimer engines I use these SCAT rods SCR6A and SCR6A7. These are both 6 inch, I beam, 4340 forgings using ARP cap screws with alignment dowels, with a bushed pin end. Both outward pinch the big end mating surface this provides a platform positioned such that it naturally resists the tendency of big ends to deform a high RPMs which reduces if not removes bending loads on the fasteners. These rods will usually clear the crankcase and cam when used on stroker motors without having to grind the rods and/or crankcase for clearance. The difference between them is the shank and outside of the mating surface shape of SCR6A is an as forged item so it costs less, while the SCR6A7 is more conformal configuration (smoother), with a surface polished and shot peened beam section.
For performance engines that will see 6000 RPM and higher I shy away from pressed pins, especially where cast hyper-eutectic pistons are used. Should these become overheated and seize the pin, a pressed-in-the-rod pin will fail the piston resulting in loss of the engine. A floating pin, bushed in the rod provides a third bearing pivot point that runs much cooler than the piston itself and therefore less likely to seize the pin. This does mean you have to buy pistons machined for pin retainers and you have to install the retainers correctly.
I'm always amazed how guys cheap out the rods. This is the highest loaded part in the engine and the most likely point of failure and the failure is almost always catastrophic to the rest of the engine. On a risk matrix where the likelihood of an event occurring and the consequences of the event occurring, failure of a rod in a high output, high RPM engine is at Likely to Almost Certain in Likelihood and Major to Catastrophic in Consequence. So rods and pistons get a really big part of my attention.
Bogie
Old 05-02-2012, 03:57 PM
cool rockin daddy's Avatar
Do people realize the only thing different about "pink" rods and other GM rods is the pink rods were magnafluxed for cracks. Other than that, the same. I'll take pm rods any day over stock GM steel rods.
Old 05-02-2012, 04:14 PM
I have abused many of SCAT rods that bogie mentioned in round track engines turning 8000+RPM for 45 minutes to an hour at time.
For a engine for a professional racer I would still go with Oliver or Carrillo but most of the guys I work for are not racing for a living.
