Lt1 Problem's - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2008, 06:39 PM
406chevycaprice's Avatar
"CHEVY"THE ANTI-RICE!!!
Lt1 Problem's
well here's the thing .when i go to start the car up it fine .i drive it around a little and then the idle will start going in and out and i hit the throttle the car will die out .now if i let it sit for about 10 min's or so it will start up just fine and i can hit the throttle and it won't die out .but then it happens all over agin.i don't know if it's the EGR vacuum solenoid valve,TPS sensor or what maybe one of you guy's mite know what's wrong
thnk's rob
Old 03-15-2008, 07:15 PM
MT71c-10's Avatar
too many toys,not enough money
Last wiki edit: Garage heating Last photo:
Wiki Edits: 13
are you EFI or carb setup?
Old 03-15-2008, 07:24 PM
I had a similar problem with a Corvette that I had. Would cold start fine, but when got warm ran awful. What I found was the wire to the temp sensor on the front of the water pump loose. This sensor tells the computer that the engine is warm and does not need to be rich. Kind of like a choke but gives motor more fuel instead of choking air.
Old 03-15-2008, 07:31 PM
yea when i got the car the sensor was broke so i replaced it .i didn't really check the wire's the see if it was broke or something .when i unplugged the EGR vac hose the motor did not stumble or change the idle and there was no vacume coming out of the hose .o yea and when i start the car i have to floor the trottle to start it or it won't start
Old 03-17-2008, 04:54 AM
yep you where right i unplugged the temp sensor on the water pump and cleaned it out .it looked a lil dirty .plugged it in and "IT WORKED".thanks man your the king dude
thanks rob
Old 03-17-2008, 05:20 AM
What computer are you running on that? OBDI or OBDII?
Old 03-17-2008, 05:16 PM
well the manual i got said the 94 caprice OBDI you can use a jumper wire to get the code's.but when i try to get the code's out it don't work so.
1970 Camaro LT1 value? Steve-0321 Hotrodding Basics 2 05-17-2005 04:04 PM
LT1 Motor Mounts Brian Hix Engine 0 09-17-2003 08:42 PM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 05:52 AM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 11:45 AM
Need LT1, or LS1 Sycotic Engine 0 09-17-2002 07:36 PM
