LT1 rotating assy into a Vortec 5.7 block opinions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2012, 10:39 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Just picked up a(nother) sweet 77 impala coupe. has a decent running 305 2 brl engine in it now,but I'm looking do do a budget 350 i have a vortec 350 short block that has a bad bottom end, haven't pulled the pan yet to see if It can be saved, but I also have a very low mileage lt1 that came out of a road master with an electrical fire, few burn sensors , but that all, wondering about installing the pistons rods and crank into the vortec block and topping it with a set of l98 heads I have laying around and a used edelbrock performer .. What do you guys think...?
any thoughts on a good roller cam?
Old 02-06-2012, 11:36 AM
DoubleVision's Avatar
What are you looking for in a roller cam? Low end torque? Mid range?
Swapping the parts over from the LT1 bottom end to the Vortec should work out okay. Not sure what style pistons the LT1 engines use, but since the L98 heads have such a small chamber you'll have to keep a close eye on the compression ratio. I have a roller cam for sale that I used in my Vortec engine. It has less than 2000 miles on it and in excellent shape, it would save you a few bucks compared to buying a new one. Shoot me a PM if your interested. Not sure if you know also but Vortec blocks require a special timing chain so I'll include it in a link:
http://www.summitracing.com/parts/CL...n/?prefilter=0
Old 02-06-2012, 12:14 PM
World Famous VF-14
Well the L98 heads I have are Iron 64cc heads, the vortec engine has dished pistons and the LT1 has flat tops...but the LT 1 heads are 64 cc to I think ..I have both the roller LT1 and the Vortec cams and I think I have a roller cam from a l98 also , Just looking mainly for low and mid range power.
Old 02-06-2012, 02:54 PM
The cam I have is a comp cams magnum .206 duration @.050 and .500 lift.
It's designed for low end torque and fuel economy.
Old 02-07-2012, 10:15 AM
World Famous VF-14
Was it that bad of an idea?
Old 02-07-2012, 11:24 AM
Not a bad idea at all, nobody is replying as you seem to already have all your answers. You know the parts will work, what else would you like to know?
Old 02-07-2012, 01:37 PM
World Famous VF-14
Mainly wondering if I would gain anything from useing the flat tops from the LT1 along with having the shorter piston skirt, over the dished vortec pistons? Opened up the bottom of the vortec today and found the crank broken between the #7 rod and the 4th main web.
Old 02-07-2012, 02:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Whether to use the FT or dished pistons comes down to simply entering the numbers (rod length, intake valve closing point and SCR) into a calculator to see if the DCR (using the cam(s) you have on hand) falls into the range of pump gas or not.
Personally, I'd spec the cam to work w/the heads and the LT1 FT pistons- even if it means buying another cam. The advantages in the quench/turbulence created by true FT pistons shouldn't be discounted. If you need more chamber volume, work the chambers to deshroud the valves and gain volume. It's not that the valves are shrouded w/1.94" intakes, but the idea is to get some benefit other than just enlarging the chambers if possible.
Old 02-07-2012, 04:05 PM
How fast is fast enough?
I would plan on getting that block line honed. Its pretty easy to open up the area arou.d the valves and gain airflow and drop compression as Cobalt said, its a win win in this case.
Old 02-07-2012, 04:20 PM
World Famous VF-14
Sounds like a plan thanks fellas. I'll prolly just use the B body LT1 cam or a truck cam, have to do some checking I know they are really close if not exactly the same.
Old 02-07-2012, 10:40 PM
If i am not mistaken the lt1 cam does not have a gear for the dist. being it is driven off the front of the engine. Lt1 heads should be 58cc?
Old 02-08-2012, 08:37 AM
The oil pump is still driven off of the rear, the gear is there.
Old 02-08-2012, 08:49 AM
Jim you wouldn't by any chance know the cc of the vortec dish piston would you?
Old 02-08-2012, 09:53 AM
World Famous VF-14
You are thinking of the LS series engines,,
the LT1 has a stuby shaft that sits under the intake
What I found on the Interwebs..
I measured the dish and found that they are 10.5 CCs, and they are .028" in the hole. I was trying to decide if not changing pistons was going to cost me too much power vs. how much money it would cost to change them.
Old 02-08-2012, 10:46 AM
Jim thanks I've been trying to find these numbers for a while now I'm using the vortec block with dish pistons I didn't know any better and used 041 head gaskets with stock deck hight 9.025 put me with 66 quench not good ! Now that you have helped me out I can take it back apart an change head gaskets 015 or 020 thanks
Eagle "ESP" Rotating Assy.. Smittydpd Engine 2 06-26-2009 05:11 AM
vortec engine 305/350 heads and rotating assembly eatonde Engine 9 12-01-2008 11:14 AM
repair of door window assy and handle assy Carl Haughey Body - Exterior 1 08-25-2005 02:29 PM
rotating assy. balancing + mixing parts TerroRx7 Hotrodding Basics 4 04-03-2005 12:48 PM
opinions on vortec heads and intakes stfinney Engine 6 11-20-2002 04:26 PM
