great idea. use the LT1 tranny too. or get a tuner to program PCM to run only the engine. still will have to get VSS from somewhere. i am in the finishing part of sewing a 94 roadmaster LT1 in a 87 astro cs. make sure the pcm has it's grounds too.
check out Shbox.com, LT1swap.com.
i got my programming from soloman; power tune and mpg.
if you don't want to go thru all that hassle of building your own wiring harness like i did there are several dozens of people out the who do pcm programming and sell the appropriate wiring harness specific to your needs.
make sure you are ready to swap a LT1 cause there is more than changing parts.
first off is going how to get 42.5 lbs of fuel pressure to the fuel rails.
amongst much more dilemmas, but there are solutions, and most of all it can be done. with rewards.
the LT1 bolts up exactly like identical to the SBC. you may have to fab a mounting location for the tranny cross member, for whatever trans you intend on using. is the donors tranny any good?
