LT1 T-56 6 speed conversion to a SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2013, 03:09 AM
Hi,
I have gotten hold of a modified LT1 T-56 transmission. It has had the clutch fork replaced with an internal hydraulic throw out bearing like in the LS1 T-56's. (I have added a couple of photos)
My question is regarding the clutch, pressure plate and flywheel requirements for this set up.
Will an LS1 clutch and pressure plate matched to my original 168t flywheel work or do I need to look at a different combination.
I have an LS1 clutch and pressure plate and they seem to clear the internals of the bellhousing ok.
Any help would be much appreciated.
Cheers Mark
ID:	92154   Click image for larger version
Old 10-26-2013, 02:04 AM
I need to alter my above post. It hasn't got a throw out bearing but a modified internal concentric slave cylinder. They modified this to make it an internal one by welding and tapping a thread to the gearbox to mount the slave cylinder. The outer dimension of the slave clylinder matches that of an LS1 however the input shaft is still the same.
lt1 conversion rocknron Engine 3 01-25-2013 04:31 AM
will LT1 6 speed mount to "85" SBC Mikemg Transmission - Rearend 6 07-23-2008 09:32 PM
LT1 conversion bigtank05 Engine 1 08-17-2007 12:41 AM
Lt1 6 Speed In A 66 Nova jamesbiggg Hotrodders' Lounge 2 11-11-2006 09:53 AM
LT1 conversion help?? SAATR Engine 4 01-09-2004 09:05 PM
