LT1 throttle cable sheath splice - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2013, 11:05 PM
Last journal entry: More information
Hi guys,
For my Jaguar Xj6/LT1 conversion, I am using the stock LT1 throttle cable end which interfaces with the throttle cable bracket. However, the stock LT1 cable sheath is too short, and the cable itself is scraping on the body of the car, where the cable goes through the firewall.
Does anyone out there know of a trick to splice cable sheath together? i can find plenty of info on splicing cable itself together, but nothing on the sheath -- i tried a red-neck method of just heat shrink tubing a small segment of cable sheath onto the LT1 sheath to protect the cable from getting frayed, but the cable is getting bunched in the sheath, which in turn makes it so when i step on the throttle, the cable moves, not my throttle body.
can anyone help me out?
Old 08-22-2013, 03:22 PM
Originally Posted by tylerwerrin View Post
Hi guys,
Yes, use a "brass align union" compression fitting. Measure the cable OD, fittings are typically availble for copper tube OD that is close enough that when the ferrule is crushed it makes a solid connection.
Not my original idea.
Bogie
DBW throttle control or strait cable throttle?? chadman322 Hotrodding Basics 0 09-03-2012 02:21 PM
Jaguar XJ6 - LT1 throttle cable construction tylerwerrin Engine 7 02-16-2012 11:57 PM
Throttle Linkage vs throttle cable 65comet Engine 2 06-02-2006 01:56 PM
Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) Viet Nam Vette Engine 4 06-13-2005 04:29 PM
Throttle cable bracketeer Engine 3 03-07-2005 06:57 PM
