lt4 temp - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2005, 07:11 PM
lt4 temp
what is the hottest an lt4 should ever run and what is a safe range? thanks
Old 05-13-2005, 12:18 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
LT4 Chevy engine
Is it safe to assume that you are talking about an LT4 Chevy engine that is fuel injected? What year is it and also what body is it in? Also is it a converted LT1 to LT4 engine? Any mods done t it?
Old 05-13-2005, 12:34 PM
it has an lt4 hot cam, yes it was an lt1, it has headers, just about everything done to the motor besides juice or a blower, its in a 1994 firebird
Old 05-13-2005, 05:23 PM
1931 steve's Avatar
Wiki Edits: 4
Temp
It all depends on the T-stat that you are running. if you run a 160 degree stat your constant temp should be aprox 170-180 degrees or if you have the factory spec T-stat of 195 degree you should be around 200-210 degrees. as long as your cooling system is functioning properly. As with everything this is just a base line temps can very up or down per car and situation. I hope this helps. I have a LT1 with the Lt4 hot cam with ported Lt1 heads and a few more tricks done to it. This engine is going into my 1931 Ford Model A Street rod. Also have a buddy that has a 1995 Camaro with a very healthy LT4 that runs very well at aprox 10"s in the 1/4. IMO I think the LT1-LT4 is a great engine, full of power and still gets good gas mileage.
Old 05-13-2005, 06:19 PM
Siggy_Freud's Avatar
Id start to worry with anything over 220 degrees.
Bringing history and technology together.
Old 05-13-2005, 10:30 PM
is the block alum. or is it just the heads? cause dont alum heads take a chance at warping with any temp over like 210?
Old 05-14-2005, 07:44 PM
Sixguns's Avatar
Going down the road, the LT4 in the Corvette runs about 193, in traffic the 1st fan comes on at 230 and the 2nd fan at 250, its the same for the LT1 and the LS1 engines. hope this helps
Old 05-14-2005, 09:08 PM
edge's Avatar
Time is short, are you ready?
If your engine runs 200*-210* with a 195* T-stat in a particular setup (car, radiator, fan, etc.), it will also run 200*-210* with a 160* T-stat. The T-stat does not determine running temperature, but the minimum temperature. Ed
Electric Fan Temp. Sensors horvath Electrical 26 04-26-2011 03:04 PM
Can a lower temp thermostat hurt my engine? CCR Engine 15 09-15-2007 06:58 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Lower temp thermostat? draft Engine 4 11-14-2004 05:04 AM
difference between water and manifold temp? smlblcks10 Engine 3 03-02-2004 02:08 PM
