lucas oil treatment - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2007, 03:22 PM
runn141's Avatar
SB S10
lucas oil treatment
i have a 350 turbo transmission, and i put 1/2 a quart of lucas oil stabilizer in it before i thought about it. i havent run the motor yet so its not to late to get it out. i was wanting to know will it damage the clutches or anything else?
Old 09-16-2007, 06:20 PM
Crosley's Avatar
Wiki Edits: 1659
I would think the additive would sit there and not harm anything.
did you add trans fluid too or only the lucas additive?
Old 09-17-2007, 01:57 PM
runn141's Avatar
SB S10
both trans fluid and less than half a bottle of lucas oil stabilizer.
Old 09-17-2007, 03:01 PM
302 Z28's Avatar
I can tell you a horror story about Lucas power steering additive. Cost my neighbor about $1500 on his motorhome. I don't use any of their stuff based on how they treated him.
Vince
Environmentally friendly honing fluid. F-BIRD'88 Engine 16 07-01-2007 10:06 AM
oil psi problem w/350 A355CAMARO Engine 2 04-19-2007 07:25 AM
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 07:36 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 12:47 PM
