lug bolt stripped
I bought a 67 camaro a few months ago. when I started to remove the back wheels which are 10" mags with plastic center caps. The lugs were so tight I had to heat them with a pencil torch to get them loose.
Now the problem, someone tried to loosen them before and stripped one off in the axle so bad it is moving around and you can turn with fingers but I have no idea how to get it out or loose to get the wheel off. Any ideas? Thanks Randy
