Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lug bolt stripped
Old 04-24-2004, 11:06 PM
cub cub is offline
Well I got the lug nut off! I don't know if this info could help someone else but here is how I did it anyway. I used a Dremnal tool with a cut off wheel on it . I cut offf the end of the lug nut and then went back as close to the mag as possible and cut it off there. I had mag taped up just in case I slipped. Then I drilled with a small drill bit
between lug and stud in 2 places.I just kept going up in size until lug nut came off. hope this helps someone. Thanks Randy
