lug nut turns on the studs 3-3/4" enough ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2007, 03:52 PM
Tonythefish's Avatar
Last journal entry: final pics
I just purchased the hopster rims . My lugs nuts only catch 3 -3/4 turns ( 5/16" ) on a 5 lug 7/16 studs . Is this enough thread to be safe ?
Old 02-15-2007, 04:14 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
NO
The top stud thread should be to the top of the nut, minimum. In other words, your nuts must be full on the studs.
Sounds like you need longer studs.
Old 02-15-2007, 04:20 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would send you home if I saw that on a race car..at least one full thread minimum visible above the lug nut is required to acheive full engagement of the nut to the stud..
Sam
Old 02-15-2007, 04:31 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Man NO...what are you thinking? Get some longer studs before you get hurt or hurt somebody.
Old 02-15-2007, 05:50 PM
I just cant understand why those hubs have such a short stud ... Thanks Will do
Old 02-15-2007, 05:53 PM
poncho62's Avatar
Wiki Edits: 5
OK...Now, what are Hopster rims?
Old 02-15-2007, 05:54 PM
Wiki Edits: 3
Your studs were probably just fine with the stock wheels but if the new ones have a thicker hub then we run out of room..
Sam
Old 02-15-2007, 05:57 PM
http://www.americanracing.com/wheels...hed&section=V#
Old 02-17-2007, 09:09 AM
Frisco's Avatar
Glad To Be Here
You need to use what are referred to as "extended thread" lugnuts. See picture below. They are designed to be used when the aftermarket rims are thicker than the original steel rims and are available in 7/16, 1/2 and metric threads. If you are going to "race" at an official dragstrip, the ET lugnuts will not pass inspection.
The only other alternative is to replace the studs with longer ones.
Old 02-19-2007, 12:38 AM
techinspector1's Avatar
Wiki Edits: 326
Here's the rule. The stud must engage the nut by the diameter of the stud minimum. 7/16" studs, 7/16" of stud in the nut.
Broken lug nut shaft headturner73 General Rodding Tech 18 10-24-2006 08:08 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
Lug nuts for wheel studs lluciano77 Transmission - Rearend 1 10-26-2005 10:34 AM
Need Help locking lug nut is rounded out!?! SLAMnomaHTZ Suspension - Brakes - Steering 9 06-20-2004 05:46 PM
Lug nut problems SOLVED!!!!!! willys36@aol.com Suspension - Brakes - Steering 3 03-15-2004 08:51 AM
