Lunati 30110 350 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 09:02 AM
does anyone have any experience or know if this is a good cam
Brand: Lunati
Product Line: Lunati Hydraulic Flat Tappet Camshafts
Part Type: Camshafts
Part Number: LUN-30110
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,500-6,000
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 287
Advertised Exhaust Duration: 296
Advertised Duration: 287 int./296 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.468 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.468 in.
Valve Lift with Factory Rocker Arm Ratio: 0.468 int./0.468 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Old 11-07-2008, 09:29 AM
TorkMonster400's Avatar
uninteresting default message
Last journal entry: A couple of pics of the car
Wiki Edits: 4
Lunati is a great company, The answer to is it a "Good" cam depends a lot on the components of the engine, transmission, stall, rear gear, tire size, weight of the vehicle, and intended use of the motor. For example car, truck, RV, boat, tractor, Tank
If you provide a bit more details on the application I think you will get a lot more responses.
Ok now I feel dumb I just saw your other thread
Old 11-07-2008, 10:18 AM
thanks for the reply
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Would like a stronger sbc 350 than stock heads. StingRay69 Engine 6 11-12-2005 03:22 PM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 07:20 PM
