Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lunati cam and 305 sbc questions in a Frankenstein
Old 04-03-2008, 04:03 PM
ImRoyaltyInMyChevy ImRoyaltyInMyChevy is offline
what do you mean exactly by putting them "end to end", because if your trying to make a v16 engine i think that would be WAY ABOVE THE SKILL LEVEL OF MOST OF THE PEOPLE HERE, you would need to weld the cranks to make one, the cam to make one, connect the water galleys so the water pump on the front engine will flow through both, and connect the oil galleys so you can use the oil pump on the back one to flow through both.
and to make it work good you need to make everything in the engines the same like bore, heads, cam, intake, and also figure out a way to make the distributer on the back run 16 plug wires lol, because it wouldn't be as even i would think with two.
sooo, I don't know what your trying to do, but maybe I'm just the one with the Frankenstein mind!
and if anyone has experience with doing this feel free to correct any of my ideas on how this would actually bed done
