Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lunati or Comp Cams valve springs?
Old 01-21-2010, 12:13 PM
JeffB's Avatar
JeffB JeffB is offline
The best thing you could do is contact the Edelbrock Techs and let them know your cam specs and go from there,they will need the part number of the heads that you have as there were options available,when you get into swapping valve springs the first thing you need to know is what matches the cam you are using and second is, will I have to machine the heads to use them.
