-   -   Lunati or Comp Cams valve springs? (http://www.hotrodders.com/forum/lunati-comp-cams-valve-springs-171796.html)
staleg 01-21-2010 07:19 AM
What's the difference between the valve springs from Comp Cams, item 26918 and Lunati item 74818?
Any of those companies to prefer before the other?
Comp Cams 26918 is the spring that fits Vortec heads without any machine work. The Lunati 74818 looks to be identical, but I might have missed something?
S10 Racer 01-21-2010 07:47 AM
Both are good companies. The thing you need to make sure of is to match the valve springs to the cam or it don't matter who makes them.
BBCMudbogger 01-21-2010 08:17 AM
What S-10 said
65ELCMO 01-21-2010 01:00 PM
So the springs that came with my Edelbrock heads need to be changed because I am using a Comp cam?
JeffB 01-21-2010 01:13 PM
The best thing you could do is contact the Edelbrock Techs and let them know your cam specs and go from there,they will need the part number of the heads that you have as there were options available,when you get into swapping valve springs the first thing you need to know is what matches the cam you are using and second is, will I have to machine the heads to use them.
S10 Racer 01-21-2010 05:25 PM
Exactly :thumbup:
