Lunati roller rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2009, 11:36 AM
Hey guys I was getting ready to install these on my 355, but I was unsure as to whether or not they'll fit under my valve covers, I have the edlebrock signature valve covers on there now.
Old 02-14-2009, 11:53 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If you have them on hand, just install one, put the cover on semi tight and see. If you have some interference on the sides, you can usually slide the covers up or down a small amount. Does Lunati state they'll fit standard covers?
Semper Fi
Old 02-14-2009, 03:15 PM
crane gold's/gasket
Well I know they are ~ the same size as my crane golds and I had to grind the corners off the 2 end rockers to make them fit, but I was also running about .100"-.200" more lift with them too..... I also plan on installing new gaskets when I make the swap so I wanna be sure theyr'e gonna fit the first time cuz this is my only daily driver right now other then the old lady's SUV... This is the set I bought from summit:
http://store.summitracing.com/partde...6&autoview=sku
If anyone else is running these or the cranes with .515" or less lift please let me know if you've had any VC clearance issues with std. height VC's... For what I paid for these I really don't wanna be grindin on em... Thanks
Danny
Old 02-14-2009, 10:05 PM
lunati rollers
im running crane energizers 1.6:1 and .532/.555 lift cam and they clear with the tall valve covers and the extra thick gaskets, i am also puttin stud girdles on tommorow,we will see if they clear but i suspect they will, if you have tall valve covers they should clear even with the regular gaskets.
Old 02-09-2015, 11:37 PM
That's weird..
roller rockers mendoza Hotrodding Basics 6 05-11-2006 02:34 AM
Cheap roller rockers? GearHead69 Engine 9 08-01-2004 12:31 AM
Roller Rockers On the street? killerformula Engine 37 06-05-2004 01:20 PM
Cheap Roller Rockers 72Olds442 Engine 3 10-27-2003 10:11 AM
Summit roller rockers warlock Engine 1 04-17-2003 04:04 PM
