lunati voo doo cam 60105 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2009, 06:57 PM
the cam has 525/546 lift i have some dart heads 200/64cc head sbc....what would be the best combo build for this cam with the heads
Old 02-26-2009, 07:04 PM
what size engine? what car? how much money you got?
Old 02-26-2009, 08:20 PM
the best build for that setup would be the biggest displacement small block you can afford.
Old 02-27-2009, 06:40 AM
lunati 60105
350 block 30 over....81 pick-up....money is good
Old 02-27-2009, 06:53 PM
a stroker crank would be a good idea, truck is a little heavy for 350 ci. 383 or larger, (401) can be built with your 350 block. the heads and cam match up well if your looking to make good power. 3000 stall is minimum to enjoy the cam and head combo, i would go 3500 stall. you will need some gear, 3.73 or higher, especially if you have 28inch or taller tires. unless you lighten the truck to about 3300lbs, going with a 350 will require 4.10 or higher gears, and minimum 3500 stall. each combo should be built to achieve around 10 to 1 compression.
Old 08-04-2012, 01:45 PM
farmwalker's Avatar
This cam calls for a minimum 10.5:1 campression, 3500 stall and a 4.11 gear ratio. a 4.10 would be close enough. But I wouldn't go with a 3.73.
And deff go with the biggest displacement possible. If money isnt that much of a problem Have you considered just geting a 400 block?? You wouldn't be spending that much more money and you will get a whole lot more cubes... Remember theres no replacement for displacement!
Old 08-04-2012, 03:09 PM
vinniekq2's Avatar
instead of building an engine to fit a cam,why not build an engine to fit an application? all cams are voodoo if you dont tell anybody what you have
Old 08-04-2012, 03:44 PM
farmwalker's Avatar
Very good point!
Cam help? Lunati 00010, XE268H, or Magnum 270? dhunt00c Engine 4 08-31-2009 10:51 AM
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 12:03 PM
I need cam help 355s10 Engine 5 03-16-2008 06:34 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
Roller Cam Help!!! Vsanthos Engine 13 10-31-2002 05:29 PM
