Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lunati voodoo 20704 cam?
Old 01-14-2013, 11:01 AM
454C10 454C10 is offline
The 292 will make around 10 inhg of vaccum at 1000 rpm and with 30 degrees of ignition timing at idle. Lower lsa reduces idle vacuum. If you want more vacuum then use wider lsa but that will reduce mid range torque.
