-   -   Lunati voodoo 20704 cam? (http://www.hotrodders.com/forum/lunati-voodoo-20704-cam-228367.html)
LJM97Z 01-13-2013 10:05 PM
Anyone running this cam in a 406 sbc, Right now i have the barebones 465/488, 224/234, Its pretty tame but does ok, just wondering if going with the voodoo 704 will be worth it? I'm running iron eagle 200cc heads, 10.4 compression, RPM intake, 750dp, 3000 stall & 3.70 gears, Its in a 78 cutlass.
vinniekq2 01-13-2013 10:42 PM
post the specs of both cams and lets discuss it? 406 is big enough to use a decent cam
Landshark928 01-13-2013 10:44 PM
That cam will work very well with your combination. Though I would step up to the 705.
454C10 01-14-2013 04:59 AM
This is one of those, "if it ain't broke then don't fix it" situations. Going to a bigger cam, especially a voodoo or extreme cam increases the chances of the cam going flat and eating up the engine bearings.
However, more cam would work better. I would use an old school Comp Cam 292H (244/244, 110 LSA, 0.501"), as it is a lot less likely to go flat due to softer ramps Get the cam hardened and use an oil additive (zddplus.com). Plus you don't need a split duration cam with those heads. Should make power a little past 6000 rpm in a 400 cid, 6500 in a 350.
Good luck!
LJM97Z 01-14-2013 10:09 AM
Good luck!
I DO like your thinking lol, i normally go under the same rule, I'm guessing the 292H will work as well as say the XE284H right? I do run the lucas "zink" additive, so far i've had no problems with both cams i've run, the other seemed to be a bit much & was hard to tune as it only got 6 inches vacuum, even advancing it didn't help much, it too was a single pattern, here are the cams i've run, now running the smaller one.
Doug Herbert FT Hyd. 510/510, 245/245 @50, 108/104 3000-7200
Cam in there now.
Lunati Barebones FT Hyd. 465/488, 224/234 @50, 112/107 2000-6000
The smaller cam is pulling 16 inches vacuum but fizzles out at around 5800
The car is a 78 cutlass, 3200 lb. with me
vinniekq2 01-14-2013 10:52 AM
Why not convert to a small roller
454C10 01-14-2013 11:01 AM
The 292 will make around 10 inhg of vaccum at 1000 rpm and with 30 degrees of ignition timing at idle. Lower lsa reduces idle vacuum. If you want more vacuum then use wider lsa but that will reduce mid range torque.
