lunati voodoo cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2008, 11:57 PM
lunati voodoo cam
What do you guyz think of the voodoo series cams and what do you think of the 60101LK voodoo cam. It would be in a 400 chevy with vortec heads and edelbrock performer manifold and carb 9.2compression. for a daily driver/off road ocassionally and tow 1978 gmc jimmy with a 4 inch lift 4 wheeldrive no revs past 5500 and needs good low end torque.
Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/219
Gross Valve Lift (Int/Exh): .454/.468
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1000-5500
Includes: Cam Kit
Old 08-02-2008, 12:57 AM
sounds fine but i'm huge on comp cams. they make the extreme energy 4x4 just for your truck pick one with your rpm range and go i promise you won't be dissapointed. i've owned three comp cams camshafts all have ran in small chevys and they always run strong to their potential if not higher. good luck either way but i just don't know anything about the voodoo cams yet
Old 08-02-2008, 02:26 AM
scottford351's Avatar
The voodoo cams were designed by Herold Brookshire formerly of Ultradyne.
I have used his solid flat tappet and solid roller stuff and am well beyond pleased with the performance
Old 08-02-2008, 11:59 AM
Guy Hiltz's Avatar
I have a UDHarold Brookshire custom ground solid roller camshaft,and I am also very pleased with it.Harold designed many of the Comp Cams line,then later the Voodoo line.From all that I have read,you cant go wrong with the Voodoo cam.
Guy
Old 08-02-2008, 01:10 PM
Guy Hiltz's Avatar
If you would like to call Harold Brookshire and ask his advice,here is his home phone #;
Harold is working for Lunati again and is making new profiles getting in touch with him is hit and miss he posted yesterday that his number is (662) 562-4933
tell him that Guy Hiltz from Nova Scotia Canada says HI !!!
Guy
Old 08-02-2008, 11:42 PM
awsome thanks for the info and the number. I'll give him a call and get his advice. I just dont want to get ths cam choice wrong cause that is the "heart" of the engine.
Power wise do you think that cam would be making strong low rpm torque? o btw the truck has 3.73 gears
Thanks,
Mike
Cam help? Lunati 00010, XE268H, or Magnum 270? dhunt00c Engine 4 08-31-2009 10:51 AM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 06:12 PM
Does anybody know where I can get Lunat Voodoo Cam for AMC? Houman SS '70 Engine 4 11-19-2007 04:53 AM
What cam specs work well with centrifugal Superchargers? hotrodf1 Engine 1 09-22-2007 05:21 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
