Lungs hurt after spraying car !!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2010, 01:47 AM
Just painted my bothers car for him in my garage today.its a detached garage and garage door in both front and back of garage. After I was finished with final clear, I was a little short of beath and sore throat,and about 30 minutes after started weasing and lungs felt a little sore when I take a good size breath. Im not coughing up anything.Will this go away ? (Im a beginner at painting but have pretty good common sense so yes i wore a 3m mask(new filters put an exhaust fan and had a door cracked for movement. I did take my mask off when I left the garage and The fumes were pretty heavy.
Old 09-20-2010, 02:05 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
What Kind of a 3m mask did you wear?
Painting is nothing to mess around with and not using proper breathing equipment will kill you.
You might want to go to the ER if the conditions continue - isocyanates crystallize the bursa sacs in your lungs and can do permanant damage.
Good luck, I hope you didn't harm yourself trying to save a buck.
Old 09-20-2010, 02:08 AM
dinger's Avatar
More importantly, what kind of paint. Google the type of paint and MSDS to find what you may up against. Or look on the cans label.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 09-20-2010, 02:11 AM
I used the one the guy at auto industrial said to. Mask is 3M 7503 and the filters are 3M 6001 NIOSH
I used a pcl sealer then a matrix white base followed by a wet pearl in clear binder the 3 coats of euro glass clear. Im pretty sure it was the clear. when i coughed i could taste it faintly
Old 09-20-2010, 02:16 AM
Ive used this mask before when I jammed my Cadillac and didnt have this problem.
Old 09-20-2010, 06:48 AM
BarryK's Avatar
Most likely was the clear, as that is what clear will do, any clear.
First of all reading your post, cracking the door is not enough air flow to protect you, mask or no mask!
This stuff will get in your tear ducts, in your skin, this is why it important to have a paint suit on and a head sock as well as eye protection.
Open the stupid door, dirt does NOT come from floor, or air (except for bugs)
Dirt comes from YOU and the CAR.
I shot two coats of silver last weekend and then 4-5 coats of the blue ink coat with the 2.5 car garage door wide open and the exhaust fan on, two specks of trash on the whole car, (and a silver wrinkle in the one door jamb, duh, on my part)
Four coats of high solids clear with door up two feet from ground and the car is as clean as any 100,000 dollar paint booth will turn out.
Point is, there is no reason to kill yourself for the sake of dirt, two people died in about the last five or so years from Iso's and they both had the same thing in common, they were spraying truck bed liners, with poor ventilation.
No need to wake up dead for a paint job.
Old 09-20-2010, 07:36 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Key point is to have lots of air flow in the paint area..One cannot have too much air..
Sam
Old 09-20-2010, 08:00 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
if you can smell it............. your dead.
Old 09-20-2010, 08:30 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
You should go see a doctor. Don't paint anything until you find out what is wrong with you. Certain people are very sensitive to isocyanates, and sensitivity can be developed by exposure.
Don't play around with this. Get to a doctor, now!
Old 09-20-2010, 11:36 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I thought that was part of the problem - the isos don't smell and can get past most filters. You don't even know your breathing it. Right? Wrong?
Old 09-20-2010, 11:48 AM
I think "odorless" is a myth - I think they have a sweet smell - but a lot of people cannot smell this and i think this is where the "odorless" myth comes from.
- Stephen
Old 09-20-2010, 12:10 PM
Also, check the fit of the mask. If you have any facial hair, I'm betting you will not get a proper fit. You can test the fit by putting on your mask, & then spraying some aerosol fragrance in the area of the mask - if you can smell it, your do not have a proper fit .
Good Luck,
Mike
Old 09-20-2010, 12:15 PM
chevymike's Avatar
Man, this is the stuff that scares the whole crap out of me when I keep thinking of doing my own paint.
Good luck man.
Old 09-20-2010, 12:17 PM
- Stephen
I don't believe there is any myth at all, they ARE odorless from what I understand. The trick is, you don't inhale ONLY the isos, you inhale solvents and such WITH isos coming along for the ride.
So you WILL smell something when you are inhaling the Isos, just not the isos themselves. This is how I understand it at least.
I'm with crash, go see a doctor!
Old 09-20-2010, 12:40 PM
Wiki Edits: 31
once you smell 'paint' then the carbon filters are used up..
Today for the first time I judged a car show. MARTINSR Hotrodders' Lounge 7 06-07-2008 06:45 AM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 03:27 PM
