m-20 clunking into 2nd
I'm curious,have you asked the person that built it about this concern?
If so what did he say? |
Sounds like syncros..............were they replaced when rebuilt?
Ontario Rodders |
New note... Spun the tires for the 1st time and when shifting into 2nd I was expecting a clunk/grind and it shifted smooth. Could I be low on fluid. I filled it until the trickled ran out of the fill hole. |
Sounds like something in the syncros is not working. Were all the Blocking rings replaced.
Professionally built is very subjective unless you actually know the parts that have been replaced or checked out. To me it sounds like a synchro problem, it should not make any grinding noise or clunking no matter how hard you shift it.
Vince |
If your trans guy put new synchronizers in maybe there was a burr on new part.
You said it is now shifting smooth,no grinding,thats good. If it stays that way,well fine. The clunk,well,clunks are not good in any transmission,ask your trans guy about that. You need to register the concern with rebuilder,or shop now,rather than later,even if noise is gone. This way if there is a big problem later the shop is culpable,and they can't blame you for dogging it and hurting the trans. If the fluid is running out of fill hole,it is full. One last suggestion,always get a list of parts installed,on any repair. Good luck! |
muncie
If you have a competition plus style shifter with the adjustable stops thats the problem....
Keith |
OK, I have to ask why. The Hurst Competition Plus shifter is one of the best 4 speed shifters on the market IMO. The stops when properly adjusted prevent transmission shifter damage. Vince |
shifter
Sorry, Vince i was in a rush and did not get to finish my statement..
I thought i had it in there but i don't On 98 percent of the muncies that have shiftimg problems after a rebuild it becaues the stops are set to short. This does not allow the slider to fully ingage the gear causing problems... If i set the shifter when i do the trans then i have zero issues.... You need to back the 2nd gear stop off 3 or 4 turns and try it to see if the problems goes away.... Keith |
| Dont shift to 2nd | buicktt85 | Transmission - Rearend | 0 | 08-09-2006 01:19 PM |
| 700R4 2nd gear start/4th gear bind up? | myclone1 | Transmission - Rearend | 3 | 04-19-2005 02:51 PM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| 700r4 shifting and 2nd gear . | eliotmansfield | Transmission - Rearend | 4 | 06-20-2004 03:09 AM |
| 700r4 shift problem,1st to 2nd | root | Transmission - Rearend | 2 | 10-19-2003 11:31 AM |
