M-20 muncie value ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 10:19 AM
1967chevelle454's Avatar
Last journal entry: Before Retoration Begins!
M-20 muncie value ?
I was wanting to know what a clean m-20 four speed was worth?
I've got a nice clean tranny I found in an old barn; it looks to be very clean on the inside but it could probably use a rebuild kit.
Old 02-01-2009, 10:58 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The value can depend on many items with the condition of the gears inside.
If you decide to sell the transmission , place an ad in the classified section.
Old 02-01-2009, 04:13 PM
Last journal entry: PICTURE TEST
worth
The single biggest deal is the date code. If it's a early small pin M-20 you may get 5 to 7 hundred. If it's a early 69 date code you may get as much as 1200 for it.
Keith
Muncie ID #'s Alan Byers Transmission - Rearend 5 10-05-2007 05:53 AM
Muncie problems Muncie guru needed chirpn69 Transmission - Rearend 8 04-19-2007 11:28 AM
Muncie hub width mr52pickup Transmission - Rearend 3 02-12-2007 07:39 AM
A turbo 350 or a Muncie m-22? n2o burner Transmission - Rearend 11 02-15-2006 07:47 AM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 06:54 AM
