Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - M-21 Muncie - What Ya Using For Lube?
Old 11-11-2012, 09:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by lakeroadster View Post
Thanks for the link.
I am wondering how big a deal it is in regards to flushing the trans to get the ATF fluid out before filling with Sta-Lube GL4 from Napa?
If the trans in in the car, do two fills.
First fill run for a short distance just to thoroughly mix the new lube w/the remaining ATF (if that's what it was and not some sort of synthetic gear lube), then dump. Second fill keep for the duration.
The smell will tell you if it was ATF if there's any question, obviously if it was piss thin you know it's not right because the correct gear lube is very viscous compared to any ATF.
