M-22 pops out of 2nd and 3rd
I have a 67 Camaro I bought about 3 months ago. I am trying to get a good driver. has 350 crate motor the transmission is a 4 speed M22. I have paper work that says it was rebuilt in 91??? for what that's worth. it is very loud in 1st,2nd and 3rd.I know they call it the ROCK CRUSHER but its ""very loud"" anyway what is my problem is it pops out of 2nd and 3rd on deceleration.it is fine in 1st and 4th I checked the fluid and topped it off! Is it time to rebuild again?
Synchro's, slider's most likely gears also, you could be lucky & have a mal-adjusted shifter, but I doubt it , sorry...
dave |
Another thought from my boss this time; check the side cover as well. The bores for the shifter shafts could be worn, which beats up the 'scissor' arrangement on the backside of the cover. This can also chew up the 'stud' part of the shift fork and create misalignment. When all this goes south, you unknowingly try to adjust out the misalignment through the shifter linkage, which only exacerbates the problem.
Is there any leaking through the sidecover or countershaft bore? |
Thank you for your help No leaking any where.maybie a little from the front and back seals but " a little" sounds like time for a pro to rebuild
again thank you for all your help |
If it was a Ford
If this was a Ford standard shaft the 1st place I would look is the input shaft bearings, then else where stripped gears etc
| T 10 pops out of 2nd. | Tall John | Transmission - Rearend | 5 | 03-12-2008 02:02 PM |
| T 10 4 spd. pops out of 2nd. HELP! | Tall John | Transmission - Rearend | 1 | 03-08-2008 09:58 AM |
| pops at idle, help please | dar130 | Engine | 9 | 02-26-2008 09:43 AM |
| pops out of gear? | raideral | Transmission - Rearend | 5 | 12-23-2007 09:13 AM |
| pops [54 ford pu] | bill plise | Introduce Yourself | 2 | 10-26-2005 07:28 PM |
