M Demon lean out of the box?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2010, 02:05 PM
750 Mighty Demon annular, on 392 stroker - according to my Innovate wideband meter, it's lean out of the box all the way up. I've set the 4-corner idle at around 13-13.5 (very hard to get the idle below 900, with or without the idle-eze) and I'm getting a vacuum of around 16", but on the road it goes to 15-16:1 all the way up. Light load is not too bad, around 14.5-15, but hard acceleration drops to 16.
Stock jets are at 70 primaries and 77 secondaries. I've gone up a couple of sizes on both, but no noticeable change. I guess I've just got to go a LOT richer on the jets - just seems odd as most people note new carbs as being very rich. Any thoughts?
Old 07-10-2010, 02:22 PM
Seems too lean. If it refuses to idle down, it could have a vacuum leak, which could cause it to be lean, especially at idle and light load. The high load lean condition is from too little jet area. Add 3 numbers to each jet and retest.
Old 07-11-2010, 10:47 AM
bentwings's Avatar
bentwings
Make sure your exhaust system is leak free at the head surface. Leaks here will show as too lean on the AFR. Even a loose header bolt will show up.
Been there.
Old 07-11-2010, 10:50 AM
DoubleVision's Avatar
I agree, check it for vacuum and exhaust leaks. It may also be a good idea to disassemble your demon and clean it. Every new demon I`ve ever delt with still has shavings in the passages from the CNC process.
mighty demon 750 htwheelz67 Engine 6 04-15-2008 08:26 PM
speed demon or mighty demon? htwheelz67 Engine 33 04-09-2008 08:17 PM
Battery Box joeford Hotrodding Basics 14 11-22-2007 03:28 PM
Does the heater box affect the engines temp? 1970Chevy Engine 21 09-22-2007 12:53 PM
To Box or Not to Box - That is the question H2Os50 Suspension - Brakes - Steering 7 06-16-2005 08:39 AM
