M II Power Rack ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2012, 05:30 PM
454 Rattler's Avatar
NEVER SATISFIED !!
M II Power Rack ID
Not really sure if this is a M II or a Thunderbird rack or maybe some other Ford unit.
It's two pieces and all steel. The mounting holes are 16" on center. Also a third mount at 12" on center.
This was being used on my 36 Ford with a Mustang II front end.
It's 3 turns lock to lock.
The rack has " Ford" cast into it along with these numbers:
6-14GCC-1
G-30
B RC-1
G 26 TFC1
^-3
^ 26
I hope these number are close enough for someone to figure out which unit it is. Thanks guys !!
454 RATTLER
Name:	pictures for car questions 001.jpg
ID:	61409   Click image for larger version
Name:	pictures for car questions 002.jpg
ID:	61410   Click image for larger version
Name:	pictures for car questions 003.jpg
Old 01-07-2012, 02:19 PM
daledove's Avatar
Looks like a mustang II to me. I've had mine out several times lately and looks just like it.
Old 01-07-2012, 04:21 PM
NEVER SATISFIED !!
Thanks, daledove.
Any suggestions for the twitch that I'll get using a SBC pump ? I'd like to hear from someone with personal experience curing the potential problem.
Thanks again.
454 RATTLER
Old 01-18-2012, 11:38 AM
pnt4u2's Avatar
Hey 454
I had the same problem, 383sbc w/Mll front end and GM p/s pump. The GM pump puts out 3.7 gpm while the Ford only needs 2gpm. You need to install a Flow Control Valve which screws into the back of the p/s pump where the p/s hose connects. This will reduce the amount of fluid and correct the "twitch". SPEEDWAY MOTORS pt# 910-32918 worked for me. This will also "stiffin" the steering some.
Old 01-18-2012, 04:58 PM
NEVER SATISFIED !!
I've heard that the 84-86 Thunderbird power rack and pinion works with the Chevy pump without and pressure or volume problems.
What do you think ?
Old 01-18-2012, 05:17 PM
Wiki Edits: 49
Borgeson offers this shim kit that lowers the pressure of the GM pump to match the Mustang rack.
Cost is under $20 and it takes about 10 minutes to install. I put one in my pro-street car and it did the job very well.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 01-19-2012, 08:08 AM
pnt4u2's Avatar
Hey 454
All I can tell you is the control valve worked for meand I am happy with it. It screws into the back and was pretty simple. It was listed for $19.98 plus s/h at www.SpeedwayMotors.com. Now you have 2 choices. Priceless!
Old 01-19-2012, 08:46 AM
NEVER SATISFIED !!
Thanks guys, I needed that ! I've been thinking this over for a long time.
Now that it's Winter around here and the car is on jack stands, it's time to act.
Thanks again !!
454 RATTLER
Old 01-20-2012, 03:49 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
6-14GCC-1
G-30
B RC-1
G 26 TFC1
^-3
^ 26
454 RATTLER
Thats a 74-78 mustang ll rack
Old 01-20-2012, 06:22 PM
NEVER SATISFIED !!
Thanks, Bad Rat. That's what I thought but, wasn't sure.
454 RATTLER
Old 01-21-2012, 12:07 AM
Bad Rat's Avatar
Wiki Edits: 2
this is the inline adjustable valve that goes between the pressure side hose and the rack gets rid of that "TWICHY feelin"
http://www.speedwaymotors.com/Adjust...lve,14895.html
I used one of these on a 36 chev worked great,
OR
this one replaces the pump valve,, much cheaper
http://www.speedwaymotors.com/power-...-valve-th.html
Old 01-21-2012, 08:53 AM
NEVER SATISFIED !!
I think I'll just replace the pump valve and give that a try first.
Too bad we'll have snow on the ground for 3 more months.
Thanks again, Bad Rat.
454 RATTLER
Old 01-22-2012, 07:09 AM
I installed the pump valve and it did not cure the problem for me . Two days ago I just finished installing the inline adjusting valve I hope this works and I am sure it will as it bleeds pressure off high side to return and you can adjust to your liking . But I will have to wait until spring arrives to test it out.
Old 01-22-2012, 08:44 AM
NEVER SATISFIED !!
Hey 363wcoupe, welcome to HR.com. Glad to have you here.
Thanks for the information. I've heard that the adjustable unit is a good choice too.
It's funny how a product works for one guy but not another. It seems to be that way with just about everything.
I guess I need to pay my money and take my chances.
Good luck with your project.
454 RATTLER
Old 01-22-2012, 10:33 AM
Bad Rat's Avatar
Wiki Edits: 2
I also had problems with the valve, it took away some of the quickness, but not enough,, so I went to the inline adjustable one and it solved the problem,, the correct adjustment might be a little aggrivating,, because its so touchy,, just a slight adjustment makes alot of differance, when you are getting close to the sweet spot,,, sometimes it feels right at crusing speed,, but not strong enough when turning when stopped,, but the right combo is there somewhere,, make sure your fluid level is correct,, that makes a big differance too,,
Altho I was using a late model pump, ( stock LS1 type) don't know if that made a differance or not with the pressure,, I just asumed all the later pumps had the same operating pressure,,
MII power rack Cape Cod Bob Suspension - Brakes - Steering 2 04-02-2009 08:54 AM
What power rack do I have?? CamSweet Suspension - Brakes - Steering 2 05-16-2008 06:55 PM
Power rack. L. Gallagher Introduce Yourself 1 11-08-2006 04:44 PM
55 POWER RACK RICK UK Suspension - Brakes - Steering 1 11-03-2002 02:04 AM
power rack yes or no wizard1932 Suspension - Brakes - Steering 2 10-16-2002 08:30 AM
