M ll Crossmember - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2006, 10:14 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
M ll Crossmember
Are all the Mustang ll cross members the same? I have been thinking of using a M ll IFS. If the cross members are all the same, I could buy a new one then go to pick-n- pull auto salvage and get rest of the component parts to have a rolling chassis.
Al
Old 02-04-2006, 07:15 AM
Wiki Edits: 49
If you're talking about aftermarket units the answer is DEFINITELY NOT. There are perhaps 3 or 4 manufacturers out there that make units that are designed correctly and a hole bunch that are just doing knock-offs that will use stock Mustang II parts. The big difference is in driveability.
Do a little reading and investigate the different name brand units. Most of them are pretty good. My personal choice has always been Heidts. Very good design which duplicates Ford's geometry exactly and quality welding. They lack a little on customer service but IMHO their unit is the best.
Good luck.
Anybody got a Mustang II crossmember laying loose or on the car but bare? SinistrV6 Suspension - Brakes - Steering 6 08-08-2005 07:15 PM
Mustang II LCA alignment with crossmember? SinistrV6 Suspension - Brakes - Steering 13 07-31-2005 08:05 PM
crossmember and drive shaft trouble rbaughman Hotrodding Basics 6 04-06-2005 04:17 PM
Remove crossmember? cletis Transmission - Rearend 3 02-11-2005 10:52 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
