My M-ll IFS with a power rack front steer which sits close to the front rail at an angle that makes the U-joint coupler rub the rail. Will a rag joint work better?
I think a rag joint has a larger diameter than a Borgenson "U" joint does so that probably won't work. You might try loosening the bolts on the rack and see if you can adjust it a little to the passenger's side and if not then I would grind the frame rail so the "U" joint clears.
Thanks Centerline, I'll try that tomorrow and see if it helps.
Al
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
