M S D Timing Control - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2012, 08:36 PM
I would like to know if i can use msd # 8680 on my 94 pontiac fbird to retard the timing. i currently run a full msd set up! dist -6al box etc. I ask this because on my current tune there is 8dg of timing pulled at all times. Thanks for any and all input.
Old 06-06-2012, 08:41 PM
spinn's Avatar
Yes, I use this on my cuda. For that hot start retard. It is mounted under the dash out if the way. Depending on how you set it for 0 , you have a ton of control over your ignition curve. It likes 12 volts.
Old 06-06-2012, 08:47 PM
Thank you sir! fixn to order one. We are doing all motor passes for a while and just want to get all the power out of it we can on motor.
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 01:08 PM
Looking for feedback on MSD 8680 dash timing control Rustydawg Electrical 6 12-12-2011 01:01 PM
Timing Control strikingthematch Engine 14 08-18-2005 06:12 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
