m/t vavle covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2008, 04:19 AM
m/t vavle covers
i got these covers off ebay the left side has 2 breathers the right side the hole isn't cut open will this harm anything or do i have to open it and put a breather on this side too. my brother says each side of the engine needs to be vented
Old 06-06-2008, 06:52 AM
Nah it will be fine this is common on circle track valve covers, so that g forces don't cause oil spillage in the constant left turns.
Old 06-06-2008, 02:52 PM
SSedan64's Avatar
You should use a PCV valve on the opposite side.
Old 06-06-2008, 02:55 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Right, I doesn't matter where you put the PCV valve but you should run one vent with a PCV and one open. you are just trying to circulate the gases that are looking for an opening
crank case evacuation with m/t valve covers cope Engine 4 06-04-2008 04:43 AM
High oil consumption with aftermarket valve covers junkyardjeff Engine 15 04-27-2008 08:14 AM
after market valve covers Kevin64 Engine 7 06-22-2003 01:56 PM
after market valve covers Kevin64 Engine 0 06-21-2003 08:47 PM
after market valve covers Kevin64 Engine 0 06-21-2003 08:09 PM
