Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - m20 to be installed!
Old 04-23-2010, 09:37 AM
pixelmonkey pixelmonkey is offline
well... life took a few twist and turns. have my project almost ready to be resurrected.
recently purchased a m20 from 68-69. no shaft play, all gears clean without chips or missing teeth and just a tiny bit of wear on the forks.
i'm looking at the transmission and wondering if it should be rebuilt before even considering installing. from visual inspection, are there key wear points that should flag it as needing rebuilt before running?
couldnt find an exact answer, but how much fluid will the transmission need? last check, 40 oz. is this correct?
