-   -   M21 4 speed speedo gear, which one (http://www.hotrodders.com/forum/m21-4-speed-speedo-gear-one-124790.html)
sapsz28 09-20-2007 05:55 PM
Hi everyone I have a 1980 Z28 M21 4speed with a 3:42 gear 26 inch tires,my question is the speedo gear is all chewed up how do I know which one to replace it with, ex-red blue green?. It came with the red one but I don't know if that is the right one when a 3:42 axle is being used,any experience out there for which colour goes with which rearend would be thankfully received and faithfully applied. thank You
Deuce 09-20-2007 07:58 PM
You must know which gear is on the output shaft ... to find the correct one that you need ...
http://www.transmissioncenter.net/64...speedogear.jpg
Note the above is NOT a Muncie but does show the relationship of the gears ... ;)
Go here ... http://www.tciauto.com/Products/Tech...eedo_gears.asp for a on-line calculator ... but you must know the gear number on the output shaft.
jimfulco 09-24-2007 10:57 PM
http://novaresource.org/speedo.htm will help you figure out what combination of gears you need.
