M21 4 speed speedo gear, which one - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2007, 04:55 PM
Hi everyone I have a 1980 Z28 M21 4speed with a 3:42 gear 26 inch tires,my question is the speedo gear is all chewed up how do I know which one to replace it with, ex-red blue green?. It came with the red one but I don't know if that is the right one when a 3:42 axle is being used,any experience out there for which colour goes with which rearend would be thankfully received and faithfully applied. thank You
Old 09-20-2007, 06:58 PM
You must know which gear is on the output shaft ... to find the correct one that you need ...
Note the above is NOT a Muncie but does show the relationship of the gears ...
Go here ... http://www.tciauto.com/Products/Tech...eedo_gears.asp for a on-line calculator ... but you must know the gear number on the output shaft.
Old 09-24-2007, 09:57 PM
http://novaresource.org/speedo.htm will help you figure out what combination of gears you need.
TH350 speedo gear calculation dawg Transmission - Rearend 1 04-30-2007 10:34 PM
TH350 drive gear replacement dawg Transmission - Rearend 8 04-28-2007 09:07 AM
TH350 Speedometer Gear Choices skeeveman Transmission - Rearend 8 02-02-2007 12:37 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
