Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - M21 4 speed speedo gear, which one
Old 09-20-2007, 07:58 PM
Deuce Deuce is offline
You must know which gear is on the output shaft ... to find the correct one that you need ...
Note the above is NOT a Muncie but does show the relationship of the gears ...
Go here ... http://www.tciauto.com/Products/Tech...eedo_gears.asp for a on-line calculator ... but you must know the gear number on the output shaft.
