M21 to T10 Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2013, 06:56 PM
I am trying to find out if the gear ratio for a Borg Warner T10 Transmision is the same as a M-21 Transmission and if anyone has any idea how to make the speedometer cable work for a 79 Camaro with the T10?
Old 01-07-2013, 12:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The ratios are the same except for third (and they're close) between the M21/22 and the close ratio T-10.
M-21/22: 2.20, 1.64, 1.28, 1.00
T-10 ratios
The Following User Says Thank You to cobalt327 For This Useful Post:
Port333@aol.com (01-07-2013)
bw transmission t10 walt687 Transmission - Rearend 1 10-19-2011 03:04 PM
Transmission Issues with a Borg Warner Super T10 Camaro83 Transmission - Rearend 9 09-08-2010 06:31 PM
T10 or T5 transmission on a Hotrod flathead.. what better easier choice? Jean Phi Transmission - Rearend 4 07-27-2008 06:53 PM
t10 swap, is t10 longer than t5? swoodard23 Transmission - Rearend 1 01-28-2003 06:44 AM
Super T10 or T10? Camaro2Fast4u Transmission - Rearend 4 01-13-2003 04:46 PM
