m22 or th350 gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2003, 02:45 PM
New Member
Post m22 or th350 gears
The problem is i want to go faster on the freeway and have the most gas mileage out of my car. I have a 72 chevelle with a hot little 350. I have a chance on getting a M-22 rock crusher and would like to know if this tranny would allow for better gas mileage and better freeway crusing RPMs on the freeway opposed to my th350. I have no idea what my rear gears are, but going 65mph on the freeway with the th350 tachs 3,000rpm.
thanks
Old 05-27-2003, 04:40 PM
Post
Both trans have a final drive ratio of 1:1. so gear ratios will not help you. I have alway been told that a manual trans requires less power to do the task at hand because its "direct" drive where as the automatic has to drive a pump and so on
Old 05-27-2003, 05:20 PM
BOBCRMAN@aol.com's Avatar
Post
plus the 350 turbo has a small percentage of slip so its not 100 percent locked up (unless you have lock up convertor)
Old 05-27-2003, 07:59 PM
New Member
Post
how about gas mileage and highway? is there going to be any difference?
Old 05-28-2003, 01:09 AM
Post
Your cruising rpm would be marginally lower with the Muncie, but not much. Your biggest headache would be your final drive ratio in first gear. Assuming you have a 26" tire, your rear gear is around 3.36 or so. Multiply that by Muncie M-22 1st gear of 2.20, and you get 7.39:1. You will probably not like this, because you will have to slip the clutch big time just to get the car moving. I had a 350 Nova with 3.08 rear & 2.54 first gear, giving me 7.82:1, and it was a pain in the butt to drive, plus wore the clutch out every 25,000miles. This was with a LARGE flywheel, stock camshaft, and a few hundred pounds less weight than you have. For Muncie (and other) gear ratios & identification info, go to <a href="http://www.dandltransmission.com" target="_blank">www.dandltransmission.com</a> If that trans turns out to be a wide ratio (M-20), you would have 8.47 final ratio, which would be much better. I have seen several "Rock Crushers" for sale that turned out not to be when properly ID'd.
Old 05-28-2003, 12:26 PM
New Member
Post
ok, thanks for that part...now, how would i find my rear gear ratio? what do i multiply the 1st gear ratio by?..and is the higher final drive ratio better because its move the car easier? and how would i measure my tires? i have 15 inch wheels with 225/60 tires.
[ May 28, 2003: Message edited by: 72HeavyChevy ]</p>
