A thought comes to mind, the fuel pumps on the common LG4 engines like the Elky, Camaro, monte`s, etc. were junk from the factory, they barely could keep up the fuel demands of a stock engine. If your still using the factory pump, or even a replacement stock pump then it`s likely the problem or is contributing to the problem. A carter replacement pump is recommended and usually cures any fuel problems. another thought is too low of float level, when you brake the fuel moves forward and if the level is too low from the fuel pump or float level it uncovers the idle circuits and the engine shuts down. Other than that the next thing that comes to mind is a vacuum leak. It doesn`t seem likely to me if it were to be one turn off that it would cause the issue. If in any doubt, back off it off half a turn, if the problem persists or gets worse, 1 turn the other direction, if it seems to get better another 1/4 at a time until it`s right. I found in the past since I didn`t have diagnostic tools to diagnose these carbs, I just used the trial and error method. Regardless, I would still change the fuel pump.
hmm i dunno
the fuel pump is brand new it seems to pump TOO much fuel you should have seen all the crazy tons of fuel spilling out over and in VERY short order it was bad way too much its definitely supplying more than enough pressure and volume, both i really dont believe i have a fuel supply issue at all, i would dare to say thta i have the opposite problem, and too much fuel, but at least now we have a good working float, needle, and seat, unlike originally, the stumble is on immediate deceleration, and not acceleration whatsoever see what i mean it runs so great now, all except this stupid stumble at deceleration now when you are accelerating donw the road and then let off the gas pedal completely it will drop the rpm way down and almost kill the engine, but most of the time it barely recovers to idle again, all while in gear going down the streeet doesn do it out of gear, any other time at all thanks!
If the needle and seat have trash in them and is stuck open it`ll overflow out of the top at idle almost regardless of how low the fuel pressure is. Is there any indication it`s flooding when you deaccelerate? One more question, is the carbon canister still in use? is the line that goes to the carbon canister connected, open or plugged off?
I tend to think that the fuel pressure is too high for the carb. I had the same problem with a Chrysler 318, the engine would idle fine for a few minutes then slow and stumble, and stop, because the fuel pressure from the replacement Electric pump was too high and overcame the carb shut-off needle valve flooding the engine. Reducing to 3/4 lbs pressure cured the problem.
| I'm going to make a bonfire out of my car | blown69stang | Engine | 36 | 08-22-2005 03:36 PM |
| How to hookup passing gear to carb? | clayboy | Transmission - Rearend | 4 | 09-20-2003 08:38 AM |
| Buick stumbles after carb work | JUSTINH | Engine | 2 | 03-18-2003 08:02 AM |
| Q-Jet Carb Problems...engine dies. | MopaRV | Engine | 8 | 01-31-2003 11:00 AM |
| no fuel inside carb when i crack the throttle open | Moteman | Engine | 2 | 09-18-2002 04:57 AM |
