M5OD-R2 VSS- cable speedo possible? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2011, 07:21 PM
Wiki Edits: 31
I'm going to be moth balling the 460 and I'm going to pick up a 300 I6 and M5OD-R2 5spd ( used in 300/302 F150's '88-'96 ) for my hotrod. I could go ither or, but want to make sure at the very least that the Ford VSS signal will work with aftermarket gauges... Or, could I take the cable drive setup from an M5OD-R2 out of a 1989-1994 Ford Ranger as they used cables? or would it have to be from the '88-'92 M5OD-R2?
The trans I have access to is from a '94 F-150 and is VSS speedo signal. '88-'91 were the only years M5OD-R2's were cable drive, and they were an option up from the T-18, so sort of hard to find.
Old 12-19-2011, 06:00 AM
tnsmith10's Avatar
when will it rain???
on the ford vss, they are already set up for a speedo cable. inside where the cable would go is a white plastic "cap" inside. remove it. the cable will go right in. only problem is the lock (metal locking clip) that holds it in. they typically dont come with it when its setup from the factory without the cable. an older (86-88 truck) vss should come with the lock.
Old 12-19-2011, 07:41 AM
Wiki Edits: 31
Is there a factory part number for the lock? in case I can't find one in a JY.
Will the M5OD-R1 ( Ford Ranger ) have the right lock ring? being '89-'94 were cable speedo?
Old 12-19-2011, 01:55 PM
tnsmith10's Avatar
it is the same vss between the 2 transmissions. at most, only the speedo gear is different.
Old 12-19-2011, 03:02 PM
Wiki Edits: 31
Thanks. Easier to find a cable driven Ranger than a cable driven F-150
Speedo cable itsandre Transmission - Rearend 1 06-13-2011 09:44 PM
VSS to cable speedo on 700R4 Thumpin455 Transmission - Rearend 5 06-13-2011 12:50 PM
TKO Speedo Cable boris_thespider Transmission - Rearend 1 01-17-2010 11:09 PM
speedo cable problems? 77formulabandit Transmission - Rearend 1 09-02-2008 06:02 PM
Electronic to cable speedo gmctruckss Transmission - Rearend 1 07-28-2006 08:45 PM
