Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - maaco or garage to rent
  #16 (permalink)
Old 08-01-2012, 07:52 PM
showtime1k showtime1k is offline
Originally Posted by timothale View Post
40 years ago I had Miracle (Franchised shops,low cost paint jobs) in northern Calif spray my car that I had prepped and spot primed. The primer spotted areas showed thru. Make sure you use a primer that is compatable with products they use.
good point. i had that problem before. what if you sprayed the areas you touched up and scuffed the clear ready for paint to be sure. that work doesnt show thru.
even though i havnt had that problem since i used regular primer first and then filler primer second.
