machening bolts to studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2007, 01:57 PM
I have a block that is in grate shape 10,000 after work. I would like to replace bolts with studs. Do I need to have honed?
I might also replace rods, pistons crank and bearings. It still has the cross hatch marks. Can I proceed or do I need to do to machine shop?
Old 10-15-2007, 02:17 PM
Guy Hiltz's Avatar
It is recommended that you have the mains align honed if you switch to studs,because force is exerted differently when torquing studs versus bolts and can cause the main caps to distort.It all depends what you are doing with it,daily driver probably doesent need studs,if its a serious performance build,get it align honed.If you are changing pistons & rods and if the weight is going to change 5 or 10 grams per unit you should have it balanced.Was the block plate honed ?? If not,now might be a good time to do that also,this will help to ensure a round hole.
studs vs bolts backyard71nova Engine 6 04-09-2007 07:56 PM
Bolts & Studs... NXS Hotrodders' Lounge 5 01-25-2006 08:14 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Main caps - studs or bolts? camaro80 Engine 6 02-06-2005 11:16 AM
Loctite on Rocker Arm Studs and Head Bolts? Bakdok Engine 13 03-30-2004 08:25 PM
