Machine Shop Tom - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2005, 09:11 AM
LilSmoke's Avatar
Machine Shop Tom
I miswrote the last question. WHat I should have said was had a slight valve seat leak,not a blower intake leak. And yes, they are set hot. This was the first fire up and were tightened to .016 and loosened to .030.So going to try .012 cold.Appreciate your time.
Old 04-28-2005, 03:05 PM
King of my Man-cave.
I'm guessing that the AJ heads are aluminum. Because this expands more than the valve and pushrod material, the lash will increase with heat.
As far as the leakdown is concerned, it may diminish as the valve is hammered home by the valve spring over time. I do recommend disassembling any head assembly and checking it out before installing it. That's a better time to find a poorly seating valve or other problem.
tom
Old 04-28-2005, 03:44 PM
LilSmoke's Avatar
Yes, They are Alan Johnson Stage II fuel heads. Everything is new, and hopefully after making a pass,they will settle down.Everything will be taken apart after ever race anyway. It is on Alc with 20%.
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
machine shop bias... onebadmerc Engine 30 02-06-2005 03:12 PM
Looking for a good machine shop. Dr.Feelgood Hotrodders' Lounge 1 11-13-2004 10:42 PM
Machine Shop Tom, if you go to PRI. . Cstraub Engine 3 11-22-2003 04:54 PM
machine shop messed up my crank??? 406chevelle Engine 7 08-01-2003 02:55 PM
