Machine Shop who'll roll rear pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2009, 11:12 AM
Howdy,
Can anyone make a recommendation of a machine shop that can roll a rear pan that's 60 inches wide? I'm in Maine and the best anyone can do around here is to make two that are 30 inches wide then I have to weld them together.
Any suggestions?
Thanks in advance,
Dan
Old 01-14-2009, 11:23 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Sheet metal fabricator should be able to do more than 30".
What is it going on?
Can you buy a pre-made?
Old 01-14-2009, 07:11 PM
cboy's Avatar
Last journal entry: Finished
If you have to start welding sections together to make your pan or you can't find a shop nearby that will do it, you might want to consider rolling your own. I've done two now using very crude tools, primarily just a length of 3" PVC to bend the metal around. And take my word for it, I'm just a glorified novice when it comes to metal work. I figure if I can do it, probably 90% of the folks on this site can do it. And it really doesn't cost you all that much money to give it a whirl. Worst case, you mangle up chunk of sheet metal. Best case...you rolled your own pan. So I really encourage you to try your hand at it.
Here's the basic "tools" I used to roll the pans:
Here's the pan I rolled for my Roadster using PVC pipe:
And a shot of it during fabrication:
And how it looks finished:
Here is a shot of the rolled pan I did for the pickup bed on my sedan delivery:
And a shot of it in primer.
You can see the step by step details of how I did the roadster pan in my journal starting here beginning at entry 96. And you can see how I rolled the pan for my pickup bed starting here beginning at entry 171.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 01-21-2009, 09:33 AM
Kevin45's Avatar
Just one of the guys
Also check with a few of the HVAC businesses in your area. Quite a few that we have in our area has a vast array of sheetmetal equipment.
CBoy...your fab skills never cease to amaze me. That bed looks Primo
Old 01-21-2009, 10:21 AM
302 Z28's Avatar
Kevin is "right on", any HVAC shop worth it's salt can do this.
Vince
Old 01-21-2009, 11:22 AM
cboy's Avatar
Thanks Kevin, but I think of it much more as fabrication ignorance rather than fabrication skill. Nobody ever took me aside and explained the things I wasn't supposed to be able to do with metal. So I just stumble forward with the banging and bending until it looks half way decent. (Oh, and you'll notice I never post pictures of my "mistake pile". BIG pile.)
Old 01-21-2009, 03:26 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
You're much to hard on yourself Dewey. I've seen your scrap pile, it's not that big...
In a while, Chet.
Old 01-30-2009, 12:54 PM
cboy, those rollpans came out beautifully. And like others said here, just give it a shot with things you can find in the garage. I had to do some small tubs for my truck, so I used a small sheet of 18 ga and rolled it longer than I needed over a spare wheel that was outside of my garage. I also use a cap from a spare welding gas tank for my shaping hammer.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Help Me Out - SBC - Machine Shop Work S10 Racer Engine 8 12-31-2007 10:34 PM
Need Help finding a Good Machine Shop RoadKing96 Engine 2 12-30-2007 12:46 PM
Pictures of a roll pan on 47-55 Chevy Pickup? wolfeman Body - Exterior 2 04-20-2004 12:47 PM
Got the Roll pan built Bluepen Body - Exterior 2 05-20-2003 05:01 AM
