-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Made me a gear lever boot. (http://www.hotrodders.com/forum/made-me-gear-lever-boot-227264.html)
staleg 12-17-2012 06:22 AM
Made me a gear lever boot and freshed up the ugly wrecking yard hand brake a bit.
http://img.photobucket.com/albums/v2...el002_komp.jpg
http://img.photobucket.com/albums/v2...el006_komp.jpg
http://img.photobucket.com/albums/v2...el008_komp.jpg
http://img.photobucket.com/albums/v2...el012_komp.jpg
http://img.photobucket.com/albums/v2...el015_komp.jpg
timothale 12-17-2012 07:06 AM
no seam ring
When you install the carpet, you can make a no seam ring around the hole. You place the vinyl-leather face down on the carpet, carpet face up , the material should overlap the hole about 2 inches. sew the material in about 1/2 inch from the hole. then cut out the hole in the vinyl at least 1/4 fron stitches then pull the material thru the hole and back under from the hole and tack stitch to hold it out.
NEW INTERIORS 12-17-2012 08:11 AM
Very cool....:thumbup:
staleg 12-17-2012 10:44 AM
Thank's for the reply & the tip, but it won't be any carpets.
