Made me a gear lever boot. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2012, 06:22 AM
staleg's Avatar
Last journal entry: Home made gear stick
Made me a gear lever boot and freshed up the ugly wrecking yard hand brake a bit.
Old 12-17-2012, 07:06 AM
Wiki Edits: 27
no seam ring
When you install the carpet, you can make a no seam ring around the hole. You place the vinyl-leather face down on the carpet, carpet face up , the material should overlap the hole about 2 inches. sew the material in about 1/2 inch from the hole. then cut out the hole in the vinyl at least 1/4 fron stitches then pull the material thru the hole and back under from the hole and tack stitch to hold it out.
Old 12-17-2012, 08:11 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
Very cool....
Old 12-17-2012, 10:44 AM
staleg's Avatar
Thank's for the reply & the tip, but it won't be any carpets.
Gear Lever CHEV MASTERS renervr Transmission - Rearend 2 07-09-2012 07:57 AM
inner downshift lever and inner manual lever. C6 ekacpuc Transmission - Rearend 1 12-28-2011 08:38 PM
Home made gear stick. staleg Hotrodding Basics 22 12-19-2011 11:57 AM
TH-350 Sun gear snap ring + shift lever channel score marks 1969ChevelleGuy Transmission - Rearend 3 02-09-2011 09:53 PM
Convert multi-function signal lever to plain lever? murrsue General Rodding Tech 0 03-07-2005 07:56 PM
