maf sensor bad with out a code? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 11:59 AM
Hello I have a 1991 olds 3.8 and was wondering if a maf could fail with out a code.........as in working but not like it should
Old 09-03-2006, 12:41 AM
Siggy_Freud's Avatar
Yes, it is highly possible and has happened to me before. Fortunately, I had a sensor scanner to read how many grams per second the MAF was sensing. I was familiar enough with my engine to know what it should read at idle and at certain RPM ranges.
Bringing history and technology together.
Old 09-03-2006, 01:30 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
been there, had that happen
if yuo can pick one up cheap, swap it out and see what happens
be sure to pull the battery terminal when you swap it so that the ECU looses its learning, that way the cars not trying to use programming it created using the bad maf
Old 09-03-2006, 11:26 AM
well I got one at a wrecking yard and put it in no change but I did not unplugg the battery.....will do that............I do have a regular electronics oscilloscope I could hook up to it but I wouldnt know what I am lookin at I just heard its supposed to output a square wave
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
code 34 on 89 iroc 8 9 iroc Electrical 2 05-26-2006 12:49 PM
MAF sensor weird problem Pony Engine 5 05-20-2004 07:10 PM
Code has me Stumped 8.5" 10 Bolt Posi Ghetto Jet Transmission - Rearend 1 03-13-2004 03:50 PM
Newer GM MAF sensor BlownBirdy Engine 3 02-10-2004 11:04 PM
