mag wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 09:04 AM
stickshift's Avatar
Last journal entry: selling the 60 chevy
mag wheels
hey anyone know what to clean magnesium wheels with i have a stain on my old fentons and cant seem to get it clean...thanks stick
Old 07-31-2005, 01:23 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
About the only thing to get it clean would be to ScotchBrite it and re- polish it. Bare aluminum and magnesium, can get stained easily from different chemicals and will go a little further than just at the surface. It will penetrate somewhat. Although not very much it still penetrates as aluminum and magnesium is porous to a certain extent. If you do not want to use ScotchBrite then I would try wetsanding with something like 800 then go to 1200 grit sandpaper. Take a look at RCastles thread about polishing. If your magnesium is not polished but has a satin look to it then you may be fine with just a uniform wetsanding and then coating with a good sealer.I haven't tried it but Zoops comes highly recommended. It is a little pricey though at a little over a hundred or was the last time I looked.
Kevin
Old 07-31-2005, 06:15 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
You can also throw it in a blast cab and hit it with some glass bead if it's really bad.
Use caution with wheel cleaners as some will turn them black due to the magnesium in it. Aluminum wheels do fine as they have little to no mag. but true mag wheels will discolor bad.
Old 08-01-2005, 09:04 AM
stickshift's Avatar
thanks for the advice,,i think ill try the scotch brite its not a bad stain it just would not clean up with anything i tried thanks again .stick
Mag Wheels Explained Nightfire Hotrodding Basics 20 08-05-2013 08:53 AM
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 01:19 AM
15x10 ET slotted mag wheels bpmatone General Rodding Tech 1 10-26-2004 10:32 PM
nostalgic slotted mag wheels mark2002 Body - Exterior 7 04-08-2004 09:06 AM
Beware Coddington Wheels! 37cabriolet General Rodding Tech 18 12-24-2003 10:24 PM
