Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Magic rust removers?
Old 02-22-2006, 05:20 PM
matt167 matt167 is online now
Wiki Edits: 31
Do you have a die grinder, if so get a 3M rollock abrasive disk kit, there inexpensive, probably the green would do ok ( second most abrasive ) but the brown ( most abrasive ) would be best, wiz it up quick, you probably could do a lot of hubs with 1 disc, also great for gasket scraping, and grinding welds. we use them at school, and I have a set at home
