Magic rust removers? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2006, 06:20 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I've had good results from a product called "The Must for Rust" available from K-mart and Wal-mart. Good on light rust, that is. The main ingredient is muriatic or a citrus based acid, I forget which. It leaves a white phosphur rust inhibiting coating that can be painted over. I used it for surface rust on a car after going over it with a wire brush wheel then 80 grit sand paper. This stuff lifted and cleaned the remaining rust and was relatively inexpensive.
  #17 (permalink)
Old 03-04-2006, 10:39 AM
roddinron's Avatar
Originally Posted by HUH?
Muratic acid is a cheap, available, effective and slightly dangerous rust
remover for small parts. It is sold is hardware stores for swimming pool
and concrete cleaning. Wear protective clothing. Use a plastic container.
Use diluted muratic acid. Pour in the water first, then add the acid, then
dunk in the parts. Store in a safe manner. Do not store near ANYTHING that will rust!
Use at your own risk. I take NO responsibility for this advice.
http://www.picturetrail.com/yelrah_dave
I reject your reality and substitute my own.
Well said, I was going to suggest it also, since I use it myself, but am always reluctant to suggest it to someone I don't know. Nice thing is it's cheap enough that you can buy a couple gallons and pour it into a PLASTIC pan like a oil change pan or something and just set the parts in and let them soak for a while. It gets into nooks and crannys where brushes can't go. Do it in a well ventilated area, and where it's safe from kids and pets, and just be careful.
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 06:23 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 12:08 PM
phosphoric acid based rust dissolver rlackey Body - Exterior 15 01-05-2006 07:07 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
