-   -   Magic rust removers? (http://www.hotrodders.com/forum/magic-rust-removers-82287.html)
gavinpierce 02-21-2006 09:16 AM
Ok, I know company's like Eastwood sell all kinds of magic product like rust dissolver and rust removers. I also know that Eastwood doesn't have any scientists working exclusivly on their products, they are just branding some typical stuff you can get at regular hardware store's for increased prices's. I have a set of wheel hubs that need to be derusted and turned for new brakes. Should I just go for a Navel jelly and a scrub brush. This is not a show car, I just want get the rust off, paint them, and get the hubs turned.
TechnTool 02-21-2006 07:46 PM
Go get a set of small cheap steel toothbrushed from the auto store near you, and scrub and wipe. nothing fancy needed. As a full time mechanic I used an air powered abrasive disk, but that's not necessary for the home mechanic.
65Stanger 02-21-2006 09:01 PM
http://www.eastwoodco.com/jump.jsp?i...ORY&itemID=372
Eastwood is good stuff
home brew 02-21-2006 09:28 PM
I've used naval jelly too. It works and is relatively cheap. I don't know how bad your drums are rusted but if you use a wire wheel on them first and then again after you've coated them they should come out great for what you need.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
gavinpierce 02-22-2006 02:32 PM
Navel jelly is the way I have always done this. I was just wondering if this Eastwood stuff was some kind of magic in a bottle. I'm pretty sure nobody here enjoys cleaning rusty parts. Has anyone used this Easwood product and navel jelly to compare the difference? I did notice that Eastwoods product does come in a jelly form, which leads me to believe that they are the same thing. Other than the price of course.
65Stanger 02-22-2006 02:35 PM
they're both really good. Eastwood has a thing that's like jb weld (in the fact that you mix it and it does what it's supposed to do, doesn't comeo ut of the bottle ready made), and it works really well. Eats the stuff up. I like naval jelly too, but man, I don't like waiting and waiting and waiting......
gavinpierce 02-22-2006 03:01 PM
I'm not very patient either, just wondering if this stuff worth spending the extra money and shipping it to my house. I too have had good luck with eastwood products, but just a little sceptical when it comes to magic solutions in a bottle. Wasn't there some old saying in the car world that went something like "Nothing out of a bottle ever fixed anything in a car"? As for removing rust, I think we all are looking for the easiest method with the least cost.
MI2600 02-22-2006 03:23 PM
A friend of mine who resurrects a lot of old frames and bodies said he's had problems with the performance of some of Eastwood's "rust" products the last few years and has stopped using them. Plus, I think their shipping is/was a little steep.
35WINDOW 02-22-2006 03:51 PM
I have used the Oxisolv, and as far as I can tell it works as promised (desolves rust, leaves zinc coating)-be sure and use Thinner afterward-
home brew 02-22-2006 04:16 PM
Have you ever heard of electrolytic rust removal? Check out this site. I have not used this process but it looks good and it sure would be cheap.
http://www.davidbradley.net/ERR.html
Picklex makes another product:
www.picklex.com
So does Zero Rust: www.zerorust.COM
Ultra One also makes a product:
http://www.safestrustremover.com/default.asp
I haven't tried any of these products but they have been talked about on various boards and the users praise them.
For the little bit of derusting you have I would just go ahead and use naval jelly. Buy locally and not have to wait for shipping and no extra shipping charges.
matt167 02-22-2006 05:20 PM
Do you have a die grinder, if so get a 3M rollock abrasive disk kit, there inexpensive, probably the green would do ok ( second most abrasive ) but the brown ( most abrasive ) would be best, wiz it up quick, you probably could do a lot of hubs with 1 disc, also great for gasket scraping, and grinding welds. we use them at school, and I have a set at home
TheHarleyMan2 02-24-2006 06:19 AM
I came across this stuff on a weblink when I was searching for some rust eaters. I am going to get me some and try it out on some small parts and see how it works, but being I will be out of town for 2 weeks for a motorcycle rally that I will be working at, I won't have any reviews for any of you until mid March.
http://www.theruststore.com/Evapo-Rust-Gallon-P1C1.aspx
HUH? 02-25-2006 09:04 PM
Rust Removal on the Cheap
Muratic acid is a cheap, available, effective and slightly dangerous rust
remover for small parts. It is sold is hardware stores for swimming pool
and concrete cleaning. Wear protective clothing. Use a plastic container.
Use diluted muratic acid. Pour in the water first, then add the acid, then
dunk in the parts. Store in a safe manner. Do not store near ANYTHING that will rust!
Use at your own risk. :nono: I take NO responsibility for this advice.
http://www.picturetrail.com/yelrah_dave
I reject your reality and substitute my own.
home brew 02-25-2006 09:42 PM
Molasses - used for livestock feed, not your kitchen molasses:
http://www.hotrodders.com/forum/rust...light=Molasses
Another set of posts about rust removal on this site:
http://www.hotrodders.com/forum/secr...light=Molasses
trees 02-26-2006 07:57 AM
There is nothing magic about rust removers. Most of us deal with Iron Oxide (Fe02) which is rusted iron(steel). The rust remover is a chemical designed to neutralize the FeO2 through chemical reaction. Those that took basic high school chemistry years ago learned that X amount of chemical A mixed with Y amount of chemical B would create a neutral solution. The rust removers could be Chemical B and your rust problem is Chemical A. You apply the rust remover to your rusted part as per instructions and when time is up, you still have some rust remaining and say it did not work well. It really did: there was just too much rest present for the amount of remover applied so you must repeat the process until all the rust is gone. To save on the over priced rust remover, you need to remove as much rust as possible through wire brushing or some other abrasive before applying the rust remover. Applying more remover to heavy rust is a waste because it will run off vice penetrating deeper.
A couple of other things are important when using rust removers. Always rinse liberally to kill all the chemical reactions. Dry as quickly as you can and add some sort of protectant as soon as dry. This fresh new metal starts the rusting process (combining oxygen in the air with the iron in the metal) immediately. A good rust inhibiting primer will kill it and seal out the air so it will not come back to haunt you. Always wear goggles or at least safety glasses when using the chemicals. Also, have a glass full of clean water available to rinse your eyes if you happen to splatter the least droplet in an eye(s).
As a side note, the reason for the wide range of costs for rust removers is usually in the concentration of the real chemical that attacks the Iron Oxide so read the labels that tell you the % of the contents. I can't remember the specific chemical you look for and would have to look on my Rust Mort to remember. Getting old is not for the weak.
Trees
